removing c.v. axles easy way |
davepalmer |
Mar 15 2018, 04:44 PM
Newbie Group: Members Posts: 1 Joined: 15-March 18 From: indiana Member No.: 21,970 Region Association: None |
take out all c.v. joint bolts and plates remove inner joint by driving thin straight blade screwdriver into gasket between joint and falange , between bolt holes gently pry turn 180 degrees and repeat . It will take several rotations repeatedly prying. REMOVING OUTER JOINT On rear of trailing arm near shock mount measure in from dust shield about 1 inch, should be on weld file or grind weld flat center punch for drill, start with 1/8 inch work your way up to 1/2 inch. Now you should be able to see the gasket between c.v. joint and stub axle Pry off like the inner joint.
Andyrew |
Mar 16 2018, 09:49 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Easy way?
Remove the big nut on the stub axle, remove the trani side cv joint bolts, pull out cv joint. If exhaust isnt in the way you can do it in 20 mins for both sides. |
Lo-Fi Version | Time is now: 10th May 2024 - 11:06 PM |
