removing c.v. axles easy way |
davepalmer |
Mar 15 2018, 04:44 PM
Newbie Group: Members Posts: 1 Joined: 15-March 18 From: indiana Member No.: 21,970 Region Association: None |
take out all c.v. joint bolts and plates remove inner joint by driving thin straight blade screwdriver into gasket between joint and falange , between bolt holes gently pry turn 180 degrees and repeat . It will take several rotations repeatedly prying. REMOVING OUTER JOINT On rear of trailing arm near shock mount measure in from dust shield about 1 inch, should be on weld file or grind weld flat center punch for drill, start with 1/8 inch work your way up to 1/2 inch. Now you should be able to see the gasket between c.v. joint and stub axle Pry off like the inner joint.
malcolm2 |
Mar 16 2018, 09:56 AM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
It has been a while, but IIRC, they were on the bench and all I did was rotate the inner section until a ball came out.
Something like that. Oh yeah, wear gloves to keep the grease off of you. There are quite a few YouTube videos for total removal and re-installation. CV videos in general and specific 914 videos. Again, IIRC the only tool needed was a bench vise. |
Lo-Fi Version | Time is now: 11th May 2024 - 05:50 PM |
