Hole in Jack Receiver Plate, Is this by design and if so what's the point? |
BeatNavy |
Mar 15 2018, 05:23 PM
I'm doing some rust repair on my DD around the bottom of the jack receiver plates on both sides. The leaves and other winter wet detritus seem to collect there, and that's probably why the PO put fiberglass / bondo repair in there that I'm now replacing with honest-to-goodness steel.
In the process of rust treatment and steel replacement I've noticed that both the driver's and passenger jack receiver plate have a hole near the top but slightly off to the side. The hole is roughly the size of a dime and appears to be there by design, but why? Wouldn't water drain into that and sit inside the receiver plate? Should I seal that up with something (like seam sealer)? I don't see any sort of similar hole on the Restoration Design replacement pieces. |
malcolm2 |
Mar 15 2018, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
BeatNavy |
Mar 15 2018, 05:54 PM
That looks like about the right size hole. Damn, I was wondering if that's what happened. Was someone dumb enough to weld some sort of replacement in upside down on both sides? It's weird, because the bottom half of each was filled with fiberglass.
Is that hole stock? |
malcolm2 |
Mar 15 2018, 06:30 PM
i don't remember mine being so large, but it was there. Dirt and water get in and it rusts. I suppose the hole was really there to drain the water.
https://www.aasesales.com/collections/body/...-r77-12d-108960 THis one has no hole. |
Mar 15 2018, 07:25 PM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Should be on the bottom.
BeatNavy |
Mar 15 2018, 07:35 PM
Ja, I was figuring that if you're going to put a hole in something it's so water can drain out, not fill in (IMG:style_emoticons/default/wacko.gif) .
Ok, I'll fill that thing in with something. |
malcolm2 |
Mar 19 2018, 07:25 AM
I found these on another thread..... Looks like the OEM, replacement parts at least, are set up to install either way. Looks like the plan was to have the movement of the car also help push the water out. But the upper hole also lets dirt in.
BeatNavy |
Mar 19 2018, 07:49 AM
Aw, that's from Michelko's thread (IMG:style_emoticons/default/smile.gif)
Good catch. Well, I just got done repairing what the PO had done some time back. I reinforced behind the jack plate, replaced the lower half of this piece with steel from RD, and plugged up that hole on top. Oh, and cleaned, treated, and painted the inside and outside of the longs and underneath the frunk. Little stiff this morning... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 12:00 PM |
