Is this transmission rod selector the same on all cars? |
Tdskip |
Mar 16 2018, 12:14 PM
Advanced Member Group: Members Posts: 3,674 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
theer |
Mar 16 2018, 12:24 PM
Senior Member Group: Members Posts: 675 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Yes, that part is what makes it a side-shifter.
A '71 would have had a tail-shifter to begin with, but it could have been converted to side-shift (using this and a bunch of other parts).. or a side-shifter tranny may have been swapped in along the way. |
Tdskip |
Mar 16 2018, 02:06 PM
Thanks for the confirmation, I'm learning but still obviously a newbie.
Dr Evil |
Mar 19 2018, 05:57 AM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Do you have the correct shift rod, and engine bar (easy to tell pieces)? Its a good upgrade and a nice find on a older car if you didnt know.
Man that thing is dirty. |
Tdskip |
Mar 19 2018, 07:29 AM
Good morning Doc, this car had a complete sideshifter set up so I have a full spare at this point, my 914/6 also has one so I've got plenty of bits now.
It looks like this donor car had a pretty significant transmission oil leak that was never addressed so it accumulated a lot of dirt over the years he |
malcolm2 |
Mar 19 2018, 07:31 AM
Advanced Member Group: Members Posts: 2,729 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Check out AutoAtlanta.com. Dr 914 has almost all of the exploded view drawings with links to part #s and dimensions. go to the transmission section, maybe one about levers etc....
but you will easily see the difference between an early tail shifter and a later side shifter. Side shifter required a different motor mount bracket (bar) too. Great source to see and learn the differences, how many washers to use, direction of bolts, all kinds of important stuff on the whole car |
Mikey914 |
Mar 19 2018, 09:48 AM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Why are you changing it out? I have (to my surprise) a 72 with the tail shifter. I had always heard the tail shifter was garbage, but I'm rethinking that now. It is every bit as good as the side shift on my 75. I think it's a little more complicated, but I've been impressed as is work very well. Perhaps it's a matter of it being a little more difficult to get adjusted correctly?
If you do change out ask Bruce Stone (BDStone) as I know he had kits put together to do the conversion. I have some of the pieces you need (bushings and such). The only think other than stock you will need is a fire wall bushing that fits the early and has the ID for the late rod (which I have also if you need it). As far as adjustment you may want to try this 1st - Attached image(s) |
Mikey914 |
Late
Tdskip |
Mar 19 2018, 10:17 AM
Why are you changing it out? I have (to my surprise) a 72 with the tail shifter. I had always heard the tail shifter was garbage, but I'm rethinking that now. It is every bit as good as the side shift on my 75. I think it's a little more complicated, but I've been impressed as is work very well. Perhaps it's a matter of it being a little more difficult to get adjusted correctly? If you do change out ask Bruce Stone (BDStone) as I know he had kits put together to do the conversion. I have some of the pieces you need (bushings and such). The only think other than stock you will need is a fire wall bushing that fits the early and has the ID for the late rod (which I have also if you need it). As far as adjustment you may want to try this 1st - Good morning - this is off the donor car, I wouldn't remove it from a car I was going to keep/ drive. I'll try to make that more clear going forward. |
Lo-Fi Version | Time is now: 29th March 2024 - 09:17 AM |
