Is this transmission rod selector the same on all cars? |
Tdskip |
Mar 16 2018, 12:14 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Mikey914 |
Mar 19 2018, 09:48 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Why are you changing it out? I have (to my surprise) a 72 with the tail shifter. I had always heard the tail shifter was garbage, but I'm rethinking that now. It is every bit as good as the side shift on my 75. I think it's a little more complicated, but I've been impressed as is work very well. Perhaps it's a matter of it being a little more difficult to get adjusted correctly?
If you do change out ask Bruce Stone (BDStone) as I know he had kits put together to do the conversion. I have some of the pieces you need (bushings and such). The only think other than stock you will need is a fire wall bushing that fits the early and has the ID for the late rod (which I have also if you need it). As far as adjustment you may want to try this 1st - Attached image(s) |
Tdskip |
Mar 19 2018, 10:17 AM
Why are you changing it out? I have (to my surprise) a 72 with the tail shifter. I had always heard the tail shifter was garbage, but I'm rethinking that now. It is every bit as good as the side shift on my 75. I think it's a little more complicated, but I've been impressed as is work very well. Perhaps it's a matter of it being a little more difficult to get adjusted correctly? If you do change out ask Bruce Stone (BDStone) as I know he had kits put together to do the conversion. I have some of the pieces you need (bushings and such). The only think other than stock you will need is a fire wall bushing that fits the early and has the ID for the late rod (which I have also if you need it). As far as adjustment you may want to try this 1st - Good morning - this is off the donor car, I wouldn't remove it from a car I was going to keep/ drive. I'll try to make that more clear going forward. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:01 PM |
