Dual Carb Problem need help |
Cazz |
Mar 17 2018, 12:38 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
Any carb specialists out there? I need help with a carb problem.
-1974 2.0 with dual weber carbs -The car is spitting and popping out the carb on cylinders 1&2and also backfiring alittle. I've rebuilt the carbs and pulled this carb off again completely taking it apart and checking with no obvious issues found -With the car idling when I put my hand over each barrel on this carb there is no suction at all on my hand. The idle doesn't drop at all. Doesn't respond to any adjustments on the fuel/air mixture screws. -The carb is injecting fuel streams when I open the linkage by hand -On the carb on the opposite side when I put my hand over each velocity stack it really pulls air really hard on my hand and the car will bog down and shut off as it should. -I have new intake gaskets an new carb base gaskets installed. I sprayed carb cleaner around the base of the carb and also at the head with no change in idle. Any ideas? Is this car basically running on 2 cylinders? -On the opposite carb on cylinders |
wndsrfr |
Mar 18 2018, 02:15 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Any carb specialists out there? I need help with a carb problem. -1974 2.0 with dual weber carbs -The car is spitting and popping out the carb on cylinders 1&2and also backfiring alittle. I've rebuilt the carbs and pulled this carb off again completely taking it apart and checking with no obvious issues found -With the car idling when I put my hand over each barrel on this carb there is no suction at all on my hand. The idle doesn't drop at all. Doesn't respond to any adjustments on the fuel/air mixture screws. -The carb is injecting fuel streams when I open the linkage by hand -On the carb on the opposite side when I put my hand over each velocity stack it really pulls air really hard on my hand and the car will bog down and shut off as it should. -I have new intake gaskets an new carb base gaskets installed. I sprayed carb cleaner around the base of the carb and also at the head with no change in idle. Any ideas? Is this car basically running on 2 cylinders? -On the opposite carb on cylinders Valve adjustment if there's no vacuum.... |
Lo-Fi Version | Time is now: 15th May 2024 - 09:46 PM |
