Front Trunk area needs assistance please, Are these parts available new or do I need to find a donor? |
BPic |
Mar 17 2018, 03:08 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
Started gutting for my rebuild and found a couple of areas needing new metal. I can fabricate if needed but if these are available somewhere I would prefer to just buy them, preferably new. In the photo the highlighted area that hold the seal for the front trunk and, also highlighted and circled in red the area that mounts the front hood release. I have a feeling this is the second hell hole on the car based on where it is welding is gonna be an issue.
IronHillRestorations |
Mar 17 2018, 03:43 PM
The cowl was available as a factory part, and it may be possible to find an NO$ piece for that but doubtful. No one is making reproductions of that area at this time
Mikey914 |
Mar 17 2018, 03:47 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ive made Cary the channel marerial for the front trunk. Just needed some feed back, but as bent oieces these will be inexpensive.
Bobco |
Mar 17 2018, 03:55 PM
Newbie Group: Members Posts: 35 Joined: 10-May 17 From: Butler pa Member No.: 21,091 Region Association: North East States |
Mark. I could use a piece of the channel if your making it.Let me know what length it comes in.Thanks Bobco
914werke |
Mar 17 2018, 05:06 PM
"I got blisters on me fingers" Group: Members Posts: 10,003 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
HERE you go.
A little rough but good for patching, & priced reasonably. (IMG:style_emoticons/default/smile.gif) |
BPic |
Mar 17 2018, 05:20 PM
Ive made Cary the channel marerial for the front trunk. Just needed some feed back, but as bent oieces these will be inexpensive. Mikey914, I am definitely interested. What kind of feed back do you need? I could use the bent piece in the photo and another 18 inches of straight to patch some other areas. |
cary |
Mar 17 2018, 07:31 PM
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels.
Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. |
cary |
Mar 17 2018, 08:28 PM
I stand corrected. Its on my own project car.
Starts about here. http://www.914world.com/bbs2/index.php?s=&...t&p=2300708 |
cary |
Mar 17 2018, 09:35 PM
bbrock |
Mar 17 2018, 10:15 PM
The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. I think that was the toughest repair I made on my car, and that was with the floor completely removed. Here's about where my saga begins: http://www.914world.com/bbs2/index.php?s=&...t&p=2563442 I could use a couple pieces of the channel too, but I'm going to try to check it off my list in within a month so won't be able to wait. (IMG:style_emoticons/default/sad.gif) |
cary |
Mar 17 2018, 10:22 PM
I don't want hold anyone up. I sure Mark can ship what he has made up already.
But they are straight pieces. One would need a shrinker stretcher to create the correct shape. IMO. |
76-914 |
Mar 18 2018, 08:18 AM
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? |
mb911 |
Mar 18 2018, 08:34 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. |
cary |
Mar 18 2018, 06:54 PM
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. That would be my guess ............................... it's steel |
Lo-Fi Version | Time is now: 25th April 2024 - 12:54 PM |
