944 Seat Belt, Receptacle |
Montreal914 |
Mar 18 2018, 03:42 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Contemplating replacing my seat belts for 944 units. From what I have read here, the pin in the back needs to be removed. (IMG:style_emoticons/default/smash.gif)
My question is; Will the standard late 914 receptacle work with the 944 belt or I also need to replace the receptacle for a matched 944 one? TIA (IMG:style_emoticons/default/beerchug.gif) |
mihai914 |
Mar 18 2018, 04:15 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Hi, the 944 belts are bolt in, no need to remove the pin on a 73 plus car.
As for the receiver, the rectangular hole 944 belt clip will insert properly in the 914 receptacle designed for a round hole. You will hear it click but the "Press" button will not fully go out. I had this setup hold in a pretty severe front end collision and the belts did their job. I would use the 944 receptacle to be 100% safe. |
Montreal914 |
Mar 18 2018, 05:03 PM
Hi, the 944 belts are bolt in, no need to remove the pin on a 73 plus car. As for the receiver, the rectangular hole 944 belt clip will insert properly in the 914 receptacle designed for a round hole. You will hear it click but the "Press" button will not fully go out. I had this setup hold in a pretty severe front end collision and the belts did their job. I would use the 944 receptacle to be 100% safe. Merci Mihai! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th April 2024 - 11:48 AM |
