Transmission Case Protection, success |
McMark |
Mar 19 2018, 07:52 AM
What to do to protect a transmission case after cleaning has been a recurring topic over the years. Originally the transmission were covered with a 'cosmoline' like product which is a mix of wax and oil to protect the metal from corrosion. These products are still available and some people are recoating trans cases with this stuff to good success.
But that coating remains sticky/tacky over time. I don't like that. So I've been trying to go the epoxy primer route. These primers form a chemically hardened coating that'll last for years, isn't sticky, and looks great. This blend of epoxy primer I used on the latest 915 transmission build is pretty much perfect color match and what I'm calling Magnesium Grey. The idea was to coat the case with something that essentially looks as close as possible to bare, oxidized magnesium. The only problem with it, is that they can't mix anything less than a gallon. (IMG:style_emoticons/default/blink.gif) So anybody need their transmission case painted? I'd love to run through this gallon ASAP. |
DRPHIL914 |
Mar 19 2018, 08:02 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
how much does it take to do one transmission? can you put it in an arisol can or can it be brushed on? I ask because my motor is out and cleaned up having degreased it before re-install but still attached to motor, and I really don't want to pull it apart -
so send it my way , let me know how much for say a pint or what it will take you think to do this - Phil -ps, got that part you sent my way, thanks, |
McMark |
Mar 19 2018, 08:11 AM
how much does it take to do one transmission? can you put it in an arisol can or can it be brushed on? I ask because my motor is out and cleaned up having degreased it before re-install but still attached to motor, and I really don't want to pull it apart - I don't have the means to put it in an aerosol. I could get it broken down into smaller quantities. But you'll need something to spray it, like the Harbor Freight HVLP spray gun. (IMG:style_emoticons/default/idea.gif)so send it my way , let me know how much for say a pint or what it will take you think to do this - -ps, got that part you sent my way, thanks, Good! I forgot to send the tracking number. Keep us posted on how your experience is with them. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:34 PM |
