Transmission Case Protection, success |
McMark |
Mar 19 2018, 07:52 AM
What to do to protect a transmission case after cleaning has been a recurring topic over the years. Originally the transmission were covered with a 'cosmoline' like product which is a mix of wax and oil to protect the metal from corrosion. These products are still available and some people are recoating trans cases with this stuff to good success.
But that coating remains sticky/tacky over time. I don't like that. So I've been trying to go the epoxy primer route. These primers form a chemically hardened coating that'll last for years, isn't sticky, and looks great. This blend of epoxy primer I used on the latest 915 transmission build is pretty much perfect color match and what I'm calling Magnesium Grey. The idea was to coat the case with something that essentially looks as close as possible to bare, oxidized magnesium. The only problem with it, is that they can't mix anything less than a gallon. (IMG:style_emoticons/default/blink.gif) So anybody need their transmission case painted? I'd love to run through this gallon ASAP. |
jcd914 |
Mar 21 2018, 01:56 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I had always been told that the cosmoline coating the factory sprayed on, was only intended to provide protection from the salt air/corrosive environment while the vehicles were shipped overseas and that vehicles staying in Europe were not even sprayed with it.
Just stuff I was told many years ago at the dealerships I worked for. Jim |
bbrock |
Mar 21 2018, 03:38 PM
I had always been told that the cosmoline coating the factory sprayed on, was only intended to provide protection from the salt air/corrosive environment while the vehicles were shipped overseas and that vehicles staying in Europe were not even sprayed with it. Just stuff I was told many years ago at the dealerships I worked for. Jim I'm pretty sure that's right. From what I've read, Tectyl is what the cases were coated with. It seems a little thicker and waxier (if that makes sense) than cosmoline, but similar. But it remains soft and waxy after it dries (like cosmoline) so I don't see it standing up long against road debris and suspect it would melt off with heat. I bought it after pulling my restoration project out of hibernation and being shocked at what my once shiny, but unprotected engine case looked like after indoor storage for 30 years. I spiffed the case back up as best I could and dabbed the Tectyl on with a foam brush. Looks kind of cool but I doubt it will last long after the car is back on the road. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1492440261.jpg) |
Lo-Fi Version | Time is now: 29th May 2024 - 06:38 PM |
