porsche 914 cranks but wont start |
widowmaker |
Mar 20 2018, 03:39 PM
Newbie Group: Members Posts: 6 Joined: 11-March 18 From: seattle Member No.: 21,957 Region Association: None |
914 runs great when it starts. Idles fine around 1200, but when it comes to starting her everyday, it's been getting a lot more difficult. When i got the ignition fixed a few months back, it fired up every time. Now it's getting back to where it used to be. I doubt it's the switch that has gone bad since it was replaced not to long ago. What else should i be focusing on? I have a multi-meter. When I let the car sit for a while, it wants to fire up right as i turn the key but doesn't have enough to start. As of today, i tried cranking for a good 15 minutes with no luck. It has never been this bad before. What do you guys suggest i do? I want to get back to (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/headbang.gif)
widowmaker |
Mar 20 2018, 04:16 PM
make sure that you have power to the positive or 15 side of the coil when cranking I'll check that now. More details. fi or carbs? last time valves were adjusted? timing set? etc dual empi epc 34 carbs nothing has been done to it since i bought it other than new ignition switch |
Lo-Fi Version | Time is now: 15th May 2024 - 12:39 PM |
