Backpad repair, Advice needed |
saigon71 |
Mar 21 2018, 11:41 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm in the process of replacing the backpad upholstery with a kit from 914 rubber.
The first step to installation is stapling the inner seam under the padding. I hit a snag right away as my backpad is weak at the top of the area and the staples won't hold. My original thought was to compress this area together and reinforce the back with fiberglass cloth and resin, but questioned weather the staples would go through the fiberglass. I wanted to check with the braintrust here before proceeding. Any suggestions from someone who has encountered this problem? Thanks! |
Mikey914 |
Mar 22 2018, 01:18 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Really the only way to do this is to use staples. the alternative is a metal strip and pop rivets. It should hold up, just non't spare the staples. I know many have done this in the past.
Lo-Fi Version | Time is now: 16th May 2024 - 06:47 AM |
