Backpad repair, Advice needed |
saigon71 |
Mar 21 2018, 11:41 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I'm in the process of replacing the backpad upholstery with a kit from 914 rubber.
The first step to installation is stapling the inner seam under the padding. I hit a snag right away as my backpad is weak at the top of the area and the staples won't hold. My original thought was to compress this area together and reinforce the back with fiberglass cloth and resin, but questioned weather the staples would go through the fiberglass. I wanted to check with the braintrust here before proceeding. Any suggestions from someone who has encountered this problem? Thanks! |
saigon71 |
Mar 28 2018, 03:54 PM
Thanks for all the input on this, much appreciated!
I mocked up a test piece to see how the fiberglass would react to staples. Then I went ahead and used the resin-cloth approach on the backside, liberally applying resin to the damaged area before laying any cloth. Everything worked out well. I ended up using 3/8" staples for this area. I had to make new cardboard fabric hold-downs for the area that gets stapled. I found something pretty close at Michaels. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:41 AM |
