What are these? |
What are these? |
kenpolives |
Jun 5 2005, 03:02 PM
Member Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 |
I got my car back from racerchris last week, Great welding on the engmankit and some other work. Now I am going though the engine bay etc and I have some questions.
What is the octagan pice and the sendor nearby (oil pressure?) This post has been edited by seanery: Jun 5 2005, 06:10 PM Attached image(s) |
kenpolives |
Jun 5 2005, 03:03 PM
Now for a part under the rear trunk that looks like something should be bolted to it (same on opp side)
This post has been edited by seanery: Jun 5 2005, 06:09 PM Attached image(s) |
kenpolives |
Jun 5 2005, 03:04 PM
Last question (for now) does the clutch cable wheel need a cover?
Garland |
Jun 5 2005, 03:11 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
1 Stock sway bar mount.
2 No cover, just keep it lubed |
URY914 |
Jun 5 2005, 03:14 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
1.That is the bolt on the dizzy clamp.
2. Rear swaybar mounts. 3. no cover. |
Aaron Cox |
Jun 5 2005, 03:24 PM
stock dizzy clamp
oil pressure idiot light sender stock rear sway mounts no cover needed |
Jun 5 2005, 06:02 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) except, i'd like to add: clean that damm tranny, that's a load of crud on there! that plastic wheel is supposed to be white-ish ... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy |
kenpolives |
Jun 5 2005, 07:24 PM
Yes Sir: cleaning now done Sir, (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
Bleyseng |
Jun 5 2005, 07:55 PM
its white nylon and the center bearing should be clean with a dab of red grease on it. The nylon wheel should spin freely btw. A lite coat of grease on the cable to wheel is gud too.
bd1308 |
Jun 5 2005, 08:02 PM
i should see if i cant cut one out of aluminum when i get back to WKU.....i'll do a set or three of trunk rollers too.....
SGB |
Jun 5 2005, 09:43 PM
an aluminum clutch pully really wouldn't be much value- it doesn't really ever wear. Now, a cover.... Actually that seems like it might be really good.
Lo-Fi Version | Time is now: 17th May 2024 - 09:00 AM |
