Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Olympic 914 |
Apr 22 2018, 11:52 AM
On Thursday took the alternator to the local FLAPS and had it tested , they said it had a fault but it passed 3 of 4 tests. still no good. so I ordered another alternator and took the bad one to a reputable local auto / truck electrical shop planning to have it rebuilt and keep as a spare... well they tested it and it and said it was good ??? (IMG:style_emoticons/default/confused24.gif) and all my regulators tested good also. Reinstalled it and it worked for two seconds, count .. one thousand one, one thousand two. before the alt light came on again.... (IMG:style_emoticons/default/mad.gif) So I figured I was out of luck for Hershey. No sense going if I can't take the car. At 10:15 on Friday morning the Flaps called and said the new alternator came in.so I hurried down to pick it up, Installed it, I had a working charging system now, and after a quick ride around the block, headed off to Hershey. Where I picked up ANOTHER regulator. this one a Bosch solid state. So 450 miles later everything is working fine.... Finally... I guess the alternator was the problem all along but intermittently working, Now I have a bunch of spare regulators and a new Bowlsby wiring harness. Thanks for your help and suggestions. Tom |
Lo-Fi Version | Time is now: 1st May 2024 - 08:43 AM |
