Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
GregAmy |
May 16 2018, 06:42 AM
Advanced Member Group: Members Posts: 2,271 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Yep. All grounds and battery cables replaced by me a couple years ago.
Have not replaced the alternator pigtail though. I wonder if that's accessible with the alternator in the car? |
dangrouche |
May 17 2018, 11:27 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Yep. All grounds and battery cables replaced by me a couple years ago. Have not replaced the alternator pigtail though. I wonder if that's accessible with the alternator in the car? the pigtail at the alternator end needs the alternator removed, and the metal cover shield removed as well. (IMG:style_emoticons/default/sad.gif) HERE IS METHOD TO TROUBLESHOOT THE INSTALLED ALTERNATOR: I did have a complete functional alternator assembly(alternator with the pigtail connected). I attached an alligator clip to the "extra alternator" body and grounded it to the car. I also did the same by connecting the positive terminal of the the external alternator to the car battery terminal. I plugged in the pigtail of the extra alternator onto the relay board. I switched the ignition key to the "on" position. I looked at the idiot light to see whether it glowed or not. (It did not glow with the installed alternator. ) The idiot light DID glow with the extra alternator, which meant installed alternator was failed (diode or brushes). At least this way, I did not have to go to the trouble of pulling and testing the installed alternator. In the end, I rebuilt the installed alternator for $15 with a pair of alternator brushes from RockAuto. |
GregAmy |
May 18 2018, 08:07 AM
the pigtail at the alternator end needs the alternator removed, and the metal cover shield removed as well. (IMG:style_emoticons/default/sad.gif) Yeah. I had the race car on the lift so looked it over last night and it needs to be removed. I've got a spare alternator on the bench, one removed some time ago, so I'm looking around to see if I can find someone to rebuild it. I'm in no rush; as noted before, best I can tell the only thing connected to the 17V on the D+ side is the GEN lamp, and with system at 13.5V it won't hurt anything for now while I get a replacement lined up. |
Lo-Fi Version | Time is now: 29th April 2024 - 08:36 PM |
