Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Sep 5 2019, 05:41 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything.
Don't touch the screwdriver to the case When doing this. |
Gatornapper |
Sep 5 2019, 06:12 PM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Ok, I can do that, but then I need someone else at my DVM to read the voltage at the battery, right?
I personally doubt this is the problem - the light comes on at a correct brightness (seems to me) when ignition is on, engine off. It would only get dim with first 2 VR's, but now seems to work correctly with the new SS VR. This would indicate to me that its wattage is correct. How much trouble to take gauge out? Don't you pull the whole instrument cluster? It's with the Temp Gauge........ Gotcha on not shorting anything...... I'm leaning toward a bad relay board. The GEN lamp and relay board are about all that's left, aren't they? It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything. Don't touch the screwdriver to the case When doing this. |
Lo-Fi Version | Time is now: 5th May 2024 - 01:11 PM |
