Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
malcolm2 |
Apr 19 2018, 07:08 AM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have had some ALT probs too. Spoke must keep that how-to and photo on a virtual clip board. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
They seemed to be re-builder problems. The last issue left me stranded. I watched my volt gauge drop and drop and drop to about 8.5 and that was it. Thank goodness I was in a Cracker Barrel parking lot. (IMG:style_emoticons/default/piratenanner.gif) Once I dis-assembled the ALT I found what might have been my issue. One of the brushes was not completely centered and 1/8" of it was not wearing down and it was extending in between the 2 copper rings. I believe the brush was touching something it was not supposed to. anyway here is a photo from my thread. My ALT Thread I have a 75 and the HE do make it impossible to get the ALT out. I removed my AUX blower, hell that thing really did not do anything anyway. (IMG:style_emoticons/default/blink.gif) I am getting pretty good at removing and installing the ALT now, but what a pain, and all the pieces and parts and sheet metal etc.... What a pain. Best answer is to buy the best ALT you can and hope it never goes out again. |
Lo-Fi Version | Time is now: 23rd April 2024 - 03:02 PM |
