Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Aug 31 2019, 08:14 PM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Try these measurements with engine running; lights on and lights off.
D+ to chassis ground. Should be 14V D- to chassis ground. Should be 0V DF to chassis ground. Should be 5-9V Battery POS post to chassis ground. Should be 14V Battery NEG post to chassis ground. Should be 0V D+, D-, DF can be measured in the plug coming from the alternator. Measure to chassis, not engine case or tin. When did this start happening? Did you do any work on the car? |
Gatornapper |
Sep 1 2019, 07:20 AM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Only work on car had nothing to do with electrical. Problem has been there since I first ran engine a couple months ago - I've not been driving the car much and have been focused on other more important mechanical needs - like brakes.
Should I read these voltages at the VR pins as well? Or only the alternator plug? BTW, I cleaned both after the NOS VR did not produce proper voltage. Seem the relay board has to be good to get the 17v with D+ & DF jumped, right? Car sat for almost 14 years...... Thanks for all these voltages to check - will do tomorrow. GN Try these measurements with engine running; lights on and lights off. D+ to chassis ground. Should be 14V D- to chassis ground. Should be 0V DF to chassis ground. Should be 5-9V Battery POS post to chassis ground. Should be 14V Battery NEG post to chassis ground. Should be 0V D+, D-, DF can be measured in the plug coming from the alternator. Measure to chassis, not engine case or tin. When did this start happening? Did you do any work on the car? |
Lo-Fi Version | Time is now: 26th April 2024 - 05:40 PM |
