Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,660 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
jcd914 |
Sep 4 2019, 05:53 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Maybe I missed in the thread but did you check voltage between the alternator body and the engine case? Should be zero.
The alternator grounds to teh engine through the mounting to the engine, unless someone has added a ground strap. There have been a few cases of painted or powder coated alternator bodies and/or mounting brackets that were preventing a good ground for the alternator. Good luck Jim |
Gatornapper |
Sep 4 2019, 08:09 PM
Senior Member Group: Members Posts: 1,191 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Jim - will check tomorrow, but checked all other places for a difference in potential with none.....glimpse of alternator I saw from below makes me think it is not original, but it wasn't painted......
All ideas appreciated..... GN Maybe I missed in the thread but did you check voltage between the alternator body and the engine case? Should be zero. The alternator grounds to teh engine through the mounting to the engine, unless someone has added a ground strap. There have been a few cases of painted or powder coated alternator bodies and/or mounting brackets that were preventing a good ground for the alternator. Good luck Jim |
Lo-Fi Version | Time is now: 17th April 2024 - 02:21 PM |
