Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Gatornapper |
Sep 4 2019, 08:23 PM
Senior Member Group: Members Posts: 1,202 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Spoke -
Will run all suggested tests tomorrow - rain coming so working in shop/garage will be fine. I am also going to run a new #6 Cu. ground wire from the battery chassis ground bolt to the shroud. Extra ground protection. Doubt it will do anything as I only got .007v potential between those two points today with engine running. Fan shroud is original. Car has only 61 k original miles - judging by pedal wear that is accurate...also by repair records I have. So when I check D- to chassis that's with the VR removed, correct? I have this sneaky feeling that the new VR I'm getting next Tuesday will show the same results as the original one and the NOS one I just got....... GN |
Spoke |
Sep 5 2019, 04:15 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So when I check D- to chassis that's with the VR removed, correct? You don't have to remove the VR for this measurement. The VR should be in the circuit. The alternator should be working though since a voltage drop here needs current to get a good measurement and that current is generated by the alternator when it is running. Voltage here is V = I x R where I is current from the alternator and R is the resistance between the alternator case and chassis. QUOTE I have this sneaky feeling that the new VR I'm getting next Tuesday will show the same results as the original one and the NOS one I just got....... GN That's also my concern. This is why I asked you to do many resistance measurements on the relay board. There's not much in the alternator circuit (alternator, VR, GEN bulb, battery) but it has several connections which could cause issues namely the relay board. |
Lo-Fi Version | Time is now: 24th April 2024 - 02:00 PM |
