Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Gatornapper |
Sep 5 2019, 04:54 PM
Senior Member Group: Members Posts: 1,201 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
I should have told you all I don't have regular problems. If they are regular, I fix them, no one knows. The plot thickened a lot today. And in my view gets worse.
1. Received new SS VR from Rock Auto today, AC Delco, is like the European one. a. Bad news: no change. 12.12 volts at battery with engine running b. Good news: GEN light is now reflecting reality - it glows. Higher I rev engine, more it glows. Light is very dim at idle tho. NO Gen light with original VR or NOS one I had. 2. I completely refreshed main ground between chassis and tranny. No change. 3. Using a very unusual bronze ground connector used by electricians I securely attached a new #6 Cu. wire to the alternator case and connected the other end to the ground/negative on the battery. NO CHANGE. Bummer. I was hoping Zach's solution would work. While I did not take voltage readings while engine was running (Spoke - DUH - of course I can probe generator cable connections - brain was not turned on.....), I did take readings with engine off. DF and D- had infinite resistance to ground. D+ had 74 ohms. 4. Just to make sure I wasn't dreaming, I again removed the VR and jumped D+ and DF, and once again, got between 16.8 and 17 volts at the battery. So alternator HAS to be good, correct? Ok, now taking readings at alternator plug terminals while engine is running. Hoping someone has some new insights..... Thanks to all for laboring with me through this mystery....... GN |
Lo-Fi Version | Time is now: 23rd April 2024 - 05:20 PM |
