Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Sep 5 2019, 05:41 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything.
Don't touch the screwdriver to the case When doing this. |
Gatornapper |
Sep 5 2019, 06:18 PM
Senior Member Group: Members Posts: 1,201 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
I have another idea: I'll bring a 1 amp fused 12+ from the battery through an 1156 bulb to D+ on the alternator plug terminal. Or a smaller lamp.......
And just touch it to energize the armature......... Whacha think? GN It makes me wonder if the VR is not starting because of insufficient current though the GEN light. Try this test. Pull out the gauge with the GEN light. Start the engine. Carefully touch a screwdriver across the GEN bulb. This is to force the VR voltage to battery voltage. See if the alternator starts up. This shouldn't damage anything. Don't touch the screwdriver to the case When doing this. |
Spoke |
Sep 5 2019, 06:41 PM
I have another idea: I'll bring a 1 amp fused 12+ from the battery through an 1156 bulb to D+ on the alternator plug terminal. Or a smaller lamp....... And just touch it to energize the armature......... Whacha think? What we're trying to do with the shorting the GEN bulb is to provide more energy to the VR and armature circuit to get the alternator to start. Once it starts, the GEN light should go out and the alternator will start working. So you don't need anyone to check with a DMM. The 1156 bulb will work as well. That's basically what you're doing with shorting the GEN light. The GEN gauge pulls out of the dash by itself. Just like the tach and speedo will pull right out. Takes a little wiggling to pull it out. Sometimes the rubber gasket stays on the gauge and sometimes the rubber gasket stays on the dash. The 1156 is a good idea. Just touch it from the battery to D+. This will provide a lot of current to the armature and should start up the alternator. About the grounding, that you can get 17V on the battery when you short D+ to DF is a good indication that the ground is at least ok. |
Gatornapper |
Sep 5 2019, 07:05 PM
Spoke -
Ok, let's assume that jumping 12+ to the armature does activate the alternator, and it's charging. Now what? Or, let's assume that jumping the 12+ does nothing - now what? Wondering where we go from either one..... TIA, GN What we're trying to do with the shorting the GEN bulb is to provide more energy to the VR and armature circuit to get the alternator to start. Once it starts, the GEN light should go out and the alternator will start working. So you don't need anyone to check with a DMM. The 1156 bulb will work as well. That's basically what you're doing with shorting the GEN light. The GEN gauge pulls out of the dash by itself. Just like the tach and speedo will pull right out. Takes a little wiggling to pull it out. Sometimes the rubber gasket stays on the gauge and sometimes the rubber gasket stays on the dash. The 1156 is a good idea. Just touch it from the battery to D+. This will provide a lot of current to the armature and should start up the alternator. About the grounding, that you can get 17V on the battery when you short D+ to DF is a good indication that the ground is at least ok. [/quote] |
Lo-Fi Version | Time is now: 23rd April 2024 - 02:45 AM |
