Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
ClayPerrine |
Sep 7 2019, 07:20 PM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
You can't use just any light for the alternator light. It has to be a particular bulb to make the circuit work.
If you can connect DF to the positive battery post with the engine running, and get 17+ volts, then the alternator and harness is good. I would change the voltage regulator. Get a Bosch regulator, not some aftermarked reproduction. |
Gatornapper |
Sep 8 2019, 05:54 AM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Clay -
The strong implication of this statement in the Pelican article, "Too low a wattage bulb will not supply enough field current for "bootstrap" operation to be reliable. The Bosch book that I have states that the lamps must be at least 2 watts for 12 volt systems.", is that a higher wattage bulb, like I used in my test, should be no problem. The problem is with a lower wattage bulb. GN You can't use just any light for the alternator light. It has to be a particular bulb to make the circuit work. If you can connect DF to the positive battery post with the engine running, and get 17+ volts, then the alternator and harness is good. I would change the voltage regulator. Get a Bosch regulator, not some aftermarked reproduction. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:10 PM |
