Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
euro911 |
Sep 8 2019, 07:25 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
At this point I'm suspecting one of the alternator diodes has gone bad.
I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) |
Spoke |
Sep 8 2019, 08:58 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
At this point I'm suspecting one of the alternator diodes has gone bad. I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) An easy way to test for burned diodes is to remove the VR and short DF to D+. The alternator will produce maximum output. At this point if all diodes are good, the battery voltage to chassis should equal the D+ voltage to chassis. |
VaccaRabite |
Sep 9 2019, 11:06 AM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
At this point I'm suspecting one of the alternator diodes has gone bad. I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) An easy way to test for burned diodes is to remove the VR and short DF to D+. The alternator will produce maximum output. At this point if all diodes are good, the battery voltage to chassis should equal the D+ voltage to chassis. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) You need to know if the alternator is doing anything. You will know immediately once DF is shorted to D+. The engine will suddenly have the full load of the alternator dragging on it and RPMs will drop. Using your meter should show 16-18 volts at idle this way. Don't do this longer then needed though, as you will be overcharging your battery. Zach |
Lo-Fi Version | Time is now: 19th April 2024 - 02:07 PM |
