Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
euro911 |
Sep 8 2019, 07:25 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
At this point I'm suspecting one of the alternator diodes has gone bad.
I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) |
Spoke |
Sep 8 2019, 08:58 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
At this point I'm suspecting one of the alternator diodes has gone bad. I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) An easy way to test for burned diodes is to remove the VR and short DF to D+. The alternator will produce maximum output. At this point if all diodes are good, the battery voltage to chassis should equal the D+ voltage to chassis. |
Gatornapper |
Sep 9 2019, 07:26 PM
Senior Member Group: Members Posts: 1,191 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Memories guys? Jerry & Zack - Long ago I jumped D+ & DF and did get full 17v at the battery and reported on that numerous times to support my view that the alternator is fine. Even ran the test multiple times.
Also put 12+v to DF as the Pelican article suggests to check all the other diodes, and it too produced a full 14.1 v at the battery, showing all the other alternator diodes are good. Today verified that the GEN light is indeed 2 watts - and just for the fun of it installed a new 2 watt lamp. No change. Thanks, GN At this point I'm suspecting one of the alternator diodes has gone bad. I'd cut to the chase and try another alternator. Maybe another local member has a (known good) spare that you can try & buy (IMG:style_emoticons/default/confused24.gif) An easy way to test for burned diodes is to remove the VR and short DF to D+. The alternator will produce maximum output. At this point if all diodes are good, the battery voltage to chassis should equal the D+ voltage to chassis. |
Spoke |
Sep 9 2019, 10:50 PM
...I jumped D+ & DF and did get full 17v at the battery... I would like you to repeat this test and measure: 1) Battery voltage to chassis 2) D+ voltage to chassis 3) GEN light goes out We're looking to see that VBAT and D+ are exactly the same. This would verify that the diodes in the VBAT path and D+ path are functioning. If VBAT not equal to D+, then diodes in the alternator may be suspect. The GEN light might be lit as well if VBAT != D+. If VBAT == D+ AND GEN light goes out, then likely the alternator is ok. This also means that the GEN light provides enough current excite the armature and to bootstrap the alternator into functionality. If the alternator passes this test, then we suspect the VR AND/OR the wiring to/from the VR. Generating a voltage at DF to excite the alternator is the responsibility of the VR. Thus my request to measure the voltages D+, DF, and D- to chassis directly at the VR connector. If D+ is less than 13-14V, then the VR should raise the voltage at DF to further excite the alternator to produce voltage/current. No voltage at the DF pin on the alternator connector with D+ less than 14V and D- around zero volts points to the VR and its wiring. |
Lo-Fi Version | Time is now: 19th April 2024 - 09:33 AM |
