Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Sep 9 2019, 11:52 PM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's a way to do a quick test on the VR. I just did this on my 914. The goal is to see if the VR will raise the voltage at DF.
There are 2 parts to this test. This is part 1; Isolation of the VR. The set up for test 1 is as follows: 1) Remove the connector to the alternator. This will remove the load on DF and isolate the VR. This also removed the ground connection to the VR which will be reconnected in step 4. 2) Remove the power to the FI ECU (if you have FI). If you have carbs, remove the ground jumper from the FI connector on the relay board. This jumper powers the fuel pump. We want the fuel pump off. 3) Remove the 12V connector to the ignition coil. This keeps the points/Pertronix/electronic points from being powered. If you have some other electronic ignition system, remove 12V power from the unit. 4) Ground the D- pin at the alternator connector on the relay board. When you disconnect the alternator plug, the VR loses its ground. I used the jumper wire from the FI ECU connector for the fuel pump to ground D- as shown below. 5) Turn the ignition key to ON. 6) Observe that the GEN light is OFF. 7) At the alternator socket on the relay board, measure D+ to chassis and DF to chassis. On my car, I measured about 10.5V at both D+ and DF. 8) Turn the ignition key to OFF. Notes: At step 7, the VR on my 914 sensed only 10.5V and attempted to drive the armature via DF to a high voltage. The resting voltage of the battery on my car was 12V. This seems low although all exterior marker lights (LEDs) were on as I've rewired the lights to come on when the ignition is ON. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 08:33 PM |
