Alternator question., Not Charging. |
Olympic 914 |
Mar 25 2018, 05:05 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner..... Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good. I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration. Now the question I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate. OR Leave the VR in place and short between those pins? |
Spoke |
Sep 10 2019, 12:04 AM
Jerry Group: Members Posts: 6,976 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Part 2 of the VR test is to check the D+ and DF voltages with the alternator connected to the VR.
The set up for test 2 is as follows: 1) If test 1 was just run, all wires are connected as needed. If test 1 was not run, do steps 1 through 4. 2) Remove the ground jumper on the D- pin at the alternator connector on the relay board. 3) Connect the alternator cable to the alternator connector on the relay board. Now the alternator/VR are connected as in the running condition. 4) Turn the ignition key to ON, do not start the car. 5) Observe the GEN light on brightly. 6) At the alternator socket on the relay board, measure D+ to chassis and DF to chassis. On my car, I measured about 2.3V at D+ and 1.5V at DF. 7) The test is done. Reconnect the FI ECU or fuel pump connections. Reconnect the ignition wires to the coil. Notes: On my 914, very little voltage was present at D+ and DF since most of the voltage was dropped across the GEN light. Even with only 2.3V at D+, the VR still raised the voltage DF to 1.5V. Once spinning when starting the car and initial engine running, this little voltage to DF should be enough for the alternator to generate at least a few more volts at D+ which will drive the DF (armature) even higher in voltage thus producing more voltage until the alternator/VR reaches 13-14V and the system is now in regulation. |
Lo-Fi Version | Time is now: 26th April 2024 - 08:20 AM |
