Fuel, Fuel Pump/hoses |
Chip |
Mar 25 2018, 10:51 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Hi everyone! My 1.7 sat for over 30 years. Need to drain tank and install new pump, lines, filter. Anyone know what size lines (braided) come out of the tank? Fuel pump has been moved to front. Also need a good fuel pump. Original Bosch is over $600.
Thanks! Attached image(s) |
TheCabinetmaker |
Mar 26 2018, 07:31 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yes, on the late style pump. No, on the braided line. The fuel will seep through the braids after the rubber breaks down from ethanol fuel. Use only hose rated for ethanol, unless you have real gas in your area.
Chip |
Apr 6 2018, 08:23 PM
Yes, on the late style pump. No, on the braided line. The fuel will seep through the braids after the rubber breaks down from ethanol fuel. Use only hose rated for ethanol, unless you have real gas in your area. You can't imagine how much you have helped me! Thanks again!! (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 06:14 AM |
