source for Schnorr washers |
brant |
Mar 30 2018, 02:22 PM
I know this thread has come along repeatedly.
I have bought them before... this time around I'm having a harder time I thought I had bought large quantity's in the past I just got an order from McMaster-carr and must have screwed up... way too small of an ID does anyone know of a bulk source with better unit pricing for say 100 of these currently? (correct size) ps. if anyone wants tiny ones... I have plenty to give away |
Elliot Cannon |
Mar 30 2018, 02:45 PM
Do you need to replenish your parts stash in the front trunk of your car? (IMG:style_emoticons/default/laugh.gif) Try here. http://metric-steel.spahrmetric.com/item/s...r-black/4585-m8?
jd74914 |
Mar 30 2018, 02:47 PM
Apologies if you know this already but if you click on the CAD logo they have dimensions for almost everything.
Mike Bellis |
Mike Bellis |
Mar 30 2018, 02:48 PM
Should be an 8mm or 10mm depending on your CV's
iankarr |
Mar 30 2018, 02:55 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Try belmetric.com?
Mikey914 |
Mar 30 2018, 04:51 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ive got them as individuals if you need them. Easy to add in if you are already on the site. These are for the CV bolts.
https://shop.914rubber.com/Schnorr-washers-...m?categoryId=-1 Order only what ypu need. Shipping reg mail is cheap too .20 each |
bdstone914 |
Mar 30 2018, 09:31 PM
8mm on standard 914 CV's. 10mm used on 911 CV's and on the top front strut mount allen head bolts, and the rear trailing arm "ears". I buy 100 at a time. I too have bought the wrong size. Got size #8 rather than 8mm. Have a life time supply of tiny Schnoor washers.
brant |
Mar 30 2018, 10:30 PM
8mm on standard 914 CV's. 10mm used on 911 CV's and on the top front strut mount allen head bolts, and the rear trailing arm "ears". I buy 100 at a time. I too have bought the wrong size. Got size #8 rather than 8mm. Have a life time supply of tiny Schnoor washers. I think that is exactly what I did. Thanks folks! |
raynekat |
Mar 30 2018, 11:41 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I buy from Belmetric.com
Can't go wrong....just make sure you order the correct size! (IMG:style_emoticons/default/wink.gif) |
wysri9 |
Mar 31 2018, 12:46 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
sithot |
Mar 31 2018, 05:16 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
cary |
Mar 31 2018, 09:13 AM
I use the black ones .........
https://www.belmetric.com/steel-c-4_39_1020...ck-p-11238.html |
rhodyguy |
Aug 7 2020, 02:13 PM
Bump for bythepool.
Lo-Fi Version | Time is now: 16th May 2024 - 07:39 AM |
