Bought a 2+L Mystery Engine, what's would you do next . |
Literati914 |
Apr 2 2018, 04:49 PM
Senior Member Group: Members Posts: 1,445 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I picked up a complete 2.0+ engine today, came with all sheetmetal, alt, starter, fan, twin Italian 40 IDF carbs, etc. The seller got it second hand from a disabled N. Texas guy who'd crashed his 'real nice orange 914 with spoilers'...he remembered that it was built in Ft. Worth TX and said that it was over-bored but could not remember the details - said "it was built to a 2 point something" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . Said the PO seemed honest and assured him that it was a fast, strong engine. It has a GA engine number. He was asking $700 for everything and I figured at the very least it was a descent price for a 2.0L + dual 40IDF webbers, so I bought it. I've asked some locals if they knew anything about it and none did.
Whats the general concensus, just do a leak down test, compression test and use it if within spec... or break it down and start taking measurement? |
MarkV |
Apr 21 2018, 11:47 AM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I don't know that there is consensus on the head gasket. I don't remember details from reading those old threads except that at least one knowledgeable person said the VW recommendation to remove them was for a specific application (only bus maybe?) and didn't apply to us. The only other part I remember was that after all the reading, I decided I will be installing them when my heads go back on, but would love to hear opinions as it is a decision that I'll be making soon as well. Tom Wilson's book has a good description for measuring deck height. It's worth having if you don't already. There is lots of information about the pros and cons but I think the consensus is not to use the sealing rings. They are prone to blowout failure, I didn't use them on my rebuild. I lapped the cylinders to the heads with valve lapping compound. |
bbrock |
Apr 22 2018, 08:23 AM
I don't know that there is consensus on the head gasket. I don't remember details from reading those old threads except that at least one knowledgeable person said the VW recommendation to remove them was for a specific application (only bus maybe?) and didn't apply to us. The only other part I remember was that after all the reading, I decided I will be installing them when my heads go back on, but would love to hear opinions as it is a decision that I'll be making soon as well. Tom Wilson's book has a good description for measuring deck height. It's worth having if you don't already. There is lots of information about the pros and cons but I think the consensus is not to use the sealing rings. They are prone to blowout failure, I didn't use them on my rebuild. I lapped the cylinders to the heads with valve lapping compound. Do you have to compensate for removing the head sealing ring with shim rings at the base of the cylinder? |
Lo-Fi Version | Time is now: 4th May 2024 - 04:09 PM |
