Bought a 2+L Mystery Engine, what's would you do next . |
Literati914 |
Apr 2 2018, 04:49 PM
Senior Member Group: Members Posts: 1,396 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I picked up a complete 2.0+ engine today, came with all sheetmetal, alt, starter, fan, twin Italian 40 IDF carbs, etc. The seller got it second hand from a disabled N. Texas guy who'd crashed his 'real nice orange 914 with spoilers'...he remembered that it was built in Ft. Worth TX and said that it was over-bored but could not remember the details - said "it was built to a 2 point something" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . Said the PO seemed honest and assured him that it was a fast, strong engine. It has a GA engine number. He was asking $700 for everything and I figured at the very least it was a descent price for a 2.0L + dual 40IDF webbers, so I bought it. I've asked some locals if they knew anything about it and none did.
Whats the general concensus, just do a leak down test, compression test and use it if within spec... or break it down and start taking measurement? |
Boomingbeetle |
Apr 2 2018, 05:07 PM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
See if she runs! Personally I'd want to pull a head and measure bore and stroke, that would definitely help if you're looking to sell it (in or out of a car). But you will likely be doing some teardown anyway if it doesn't run... Or you can connect a graduated cylinder to a compression tester hose, fill the motor cylinder with oil, turn it by hand and measure displacement of the motor cylinder on the graduated cylinder gauge. multiply x4 and you've got a very close estimate of displacement
rgalla9146 |
Apr 2 2018, 06:29 PM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
See if she runs! Personally I'd want to pull a head and measure bore and stroke, that would definitely help if you're looking to sell it (in or out of a car). But you will likely be doing some teardown anyway if it doesn't run... Or you can connect a graduated cylinder to a compression tester hose, fill the motor cylinder with oil, turn it by hand and measure displacement of the motor cylinder on the graduated cylinder gauge. multiply x4 and you've got a very close estimate of displacement I agree. |
Lo-Fi Version | Time is now: 28th March 2024 - 11:45 PM |
