Bought a 2+L Mystery Engine, what's would you do next . |
Literati914 |
Apr 2 2018, 04:49 PM
Senior Member Group: Members Posts: 1,396 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I picked up a complete 2.0+ engine today, came with all sheetmetal, alt, starter, fan, twin Italian 40 IDF carbs, etc. The seller got it second hand from a disabled N. Texas guy who'd crashed his 'real nice orange 914 with spoilers'...he remembered that it was built in Ft. Worth TX and said that it was over-bored but could not remember the details - said "it was built to a 2 point something" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . Said the PO seemed honest and assured him that it was a fast, strong engine. It has a GA engine number. He was asking $700 for everything and I figured at the very least it was a descent price for a 2.0L + dual 40IDF webbers, so I bought it. I've asked some locals if they knew anything about it and none did.
Whats the general concensus, just do a leak down test, compression test and use it if within spec... or break it down and start taking measurement? |
porschetub |
Apr 2 2018, 11:33 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Check it over out of the car ,give it a clean if needs be,replace rocker cover gaskets after checking valve clearances,check over the carb linkage and make sure both carbs are even on the linkages,clean air cleaners etc etc,all this work is easier out of the car.
I purchased my 911 motor with ZERO history,only thing I knew was the plugs were a good colour and the motor was clean,turned out to be a great running motor count myself as being very lucky. Treat this motor as a total unknown,when you have got it running change the oil and filter after its fully warmed up,good luck. |
Lo-Fi Version | Time is now: 28th March 2024 - 11:12 PM |
