Bought a 2+L Mystery Engine, what's would you do next . |
Literati914 |
Apr 2 2018, 04:49 PM
Senior Member Group: Members Posts: 1,432 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I picked up a complete 2.0+ engine today, came with all sheetmetal, alt, starter, fan, twin Italian 40 IDF carbs, etc. The seller got it second hand from a disabled N. Texas guy who'd crashed his 'real nice orange 914 with spoilers'...he remembered that it was built in Ft. Worth TX and said that it was over-bored but could not remember the details - said "it was built to a 2 point something" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . Said the PO seemed honest and assured him that it was a fast, strong engine. It has a GA engine number. He was asking $700 for everything and I figured at the very least it was a descent price for a 2.0L + dual 40IDF webbers, so I bought it. I've asked some locals if they knew anything about it and none did.
Whats the general concensus, just do a leak down test, compression test and use it if within spec... or break it down and start taking measurement? |
falcor75 |
Apr 3 2018, 03:06 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
You can measure the stroke with a piece of wood or tig welding rod thru the spark plug hole by compairing the bottom/top position of the piston. It wont be 100% accurate but should give you an indication of its a stock 71 mm stroke or a 78 mm stroke.
Other than that, change the oil and filter, adjust the valves, set the timing and fire it up. |
maf914 |
Apr 3 2018, 08:16 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
You can measure the stroke with a piece of wood or tig welding rod thru the spark plug hole by compairing the bottom/top position of the piston. It wont be 100% accurate but should give you an indication of its a stock 71 mm stroke or a 78 mm stroke. It may be time to resurrect the famous chop stick thread. (IMG:style_emoticons/default/laugh.gif) |
TheCabinetmaker |
Apr 3 2018, 08:40 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You can measure the stroke with a piece of wood or tig welding rod thru the spark plug hole by compairing the bottom/top position of the piston. It wont be 100% accurate but should give you an indication of its a stock 71 mm stroke or a 78 mm stroke. It may be time to resurrect the famous chop stick thread. (IMG:style_emoticons/default/laugh.gif) Nooooo! Well, maybe yes. Always need a good laugh! |
Lo-Fi Version | Time is now: 23rd April 2024 - 04:27 PM |
