Bought a 2+L Mystery Engine, what's would you do next . |
Literati914 |
Apr 2 2018, 04:49 PM
Senior Member Group: Members Posts: 1,427 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I picked up a complete 2.0+ engine today, came with all sheetmetal, alt, starter, fan, twin Italian 40 IDF carbs, etc. The seller got it second hand from a disabled N. Texas guy who'd crashed his 'real nice orange 914 with spoilers'...he remembered that it was built in Ft. Worth TX and said that it was over-bored but could not remember the details - said "it was built to a 2 point something" (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) . Said the PO seemed honest and assured him that it was a fast, strong engine. It has a GA engine number. He was asking $700 for everything and I figured at the very least it was a descent price for a 2.0L + dual 40IDF webbers, so I bought it. I've asked some locals if they knew anything about it and none did.
Whats the general concensus, just do a leak down test, compression test and use it if within spec... or break it down and start taking measurement? |
Literati914 |
Apr 22 2018, 11:04 AM
Do you have to compensate for removing the head sealing ring with shim rings at the base of the cylinder? I'd assume if we could locate shims for the case side, that equals what was already there + the thickness of the seal rings - then replacing the shims would be ideal for maintaining the compression ration. However, like was mentioned those seal rings are really thin, so I'm not sure if it's possible. I plan to lap the head/cylinders, it's common procedure when deleting the seal rings but another questions I've been wondering.. is there any such lapping done at the case side with cylinders, shims, case ? Also, have I read that there's a paper gasket that gets eliminated too? |
Lo-Fi Version | Time is now: 18th April 2024 - 05:23 PM |
