Build Thread: Restoration and New School V8, Photogrammetry: Pics to CAD |
Joemo5 |
Apr 5 2018, 12:07 AM
Member Group: Members Posts: 54 Joined: 1-April 18 From: Charlotte, North Carolina Member No.: 22,011 Region Association: South East States |
I probably should have joined 914world and started posting earlier but I have been reading and learning ALOT about these cars already from whats posted in other threads. For that, I thank you guys. I have some catching up to do. Heres my story.
I picked up my first 914 a few months ago as a project car that could eventually serve as a track car or weekend toy. Out of the many different types of cars that would make cool projects, I ended up with the 914 in my crosshairs after I discovered that not only they were mid engine but v8 swaps where not uncommon. Other factors include I had never came across one in the wild, which makes them rare to me. I also like the idea of following in my fathers footsteps with a mid engine european car. He had a Lotus Europa in is 20's. Jumping back the v8 idea though, the added weight of a more powerful drivetrain is at the center of the car, meaning there is a minimal increase in the rotational moment of inertia: the car should retain it's handling characteristics better than a v8 swap in a comparable sized car with a forward mounted engine. After investigating several craigslist ads that turned out to have missing titles, a friend pointed me towards a local Porsche shop that was known for 914's. Bingo. More 914's than I expected. A few short conversations led to a cheap car that needed some work and was up for grabs. Heres what the '75 2.0l car looked like prior to being yanked out of the weeds. On the trailer headed home Some of my buddies and I broke out a pressure washer and the car looks good for sitting outside for a year or two. The car did not have the original engine or trans installed when purchased. Although, they were included in the sale. Some tinkering around got some of the electronics working off a jump start box Now heres the fun part. A month or two later, I came across a craigslist deal that would add some originality to the project. An 5.3l L83 out of a 2015 silverado with only "15,000" miles for $1200. Would an engine with 15,000 miles still have the assembly grease in between the rocker and top of the valve? (IMG:style_emoticons/default/confused24.gif) For those of you unfamiliar with this engine: It's NOT an LS, its part of the EcoTec Gen V family. The next generation of Chevy v8 that shares some of the architecture with the LS but with direct injection and variable valve timing. Also its an aluminum block which is different from the Gen IV 5.3 truck blocks which were cast iron. Rumor has it that GM is offering a stand alone kit for the gen V engines which, while costly, would simplify the install a lot. Quick specs: Stock 380hp and 416 ft-lbs on e85 fuel. 11.0:1 compression ratio ~400lb dressed. Anyone know how much the original 2.0l engine weighs? At this point I'm sure most of you have thought: "What does the hell hole look like?" The rot is the worst of all the ones I have viewed online. The only saving grace is that after selling the original motor, trans and wheels, I have made back the purchase price of the car and have a few bucks in my pocket. I have some experience in fabrication and plan on being a sheet metal pro by the end of all this. Heres a shot of the floor pans and fire wall area. At this point the car is stripped and ready to be mounted on a rotisserie. Lots of bracing prior to mounting on the rotisserie of course. I have more pics and more details but that should do for now. Attached image(s) |
BIGKAT_83 |
Apr 5 2018, 06:43 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Wondered how long it would be before someone used a GenV engine. I suspect most of the early LS clutch and flywheel things will work. I know the engine mounts are in a different location.
The high pressure fuel pump is located under the intake on the engine. What kind of pressure to you need to feed this pump? (IMG:style_emoticons/default/welcome.png) |
Joemo5 |
Apr 5 2018, 09:56 AM
Wondered how long it would be before someone used a GenV engine. I suspect most of the early LS clutch and flywheel things will work. I know the engine mounts are in a different location. The high pressure fuel pump is located under the intake on the engine. What kind of pressure to you need to feed this pump? (IMG:style_emoticons/default/welcome.png) From what I have read, the feed pump should be 50-60 psi which is common of cars these days. The tricky part is the engine ecu controls a PWM pump in a returnless system. |
914forme |
Apr 5 2018, 10:32 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
From what I have read, the feed pump should be 50-60 psi which is common of cars these days. The tricky part is the engine ecu controls a PWM pump in a returnless system. (IMG:style_emoticons/default/welcome.png) Then lets get into this a bit deeper. What makes that a complicated system? Take what we like to call in the diesel world the feed pump, and mount it as close to the tank as you can get. Run one feed line back to the engine, and to the real EFI high pressure pump. All my diesel are ran this way. Even the tractors are ran like this. These are need because they are all direct injection. Takes a huge amount of PSI to over come the compression on the engine. Diesels normally see, 1500 psi or more on the injector side of the pump. BTW the feed / boaster/ first pump have a return, it is that most are now mounted in the tank, so the return is just dumped into the tank, no extra lines etc... seen. |
Joemo5 |
Apr 5 2018, 11:39 AM
From what I have read, the feed pump should be 50-60 psi which is common of cars these days. The tricky part is the engine ecu controls a PWM pump in a returnless system. (IMG:style_emoticons/default/welcome.png) Then lets get into this a bit deeper. What makes that a complicated system? Take what we like to call in the diesel world the feed pump, and mount it as close to the tank as you can get. Run one feed line back to the engine, and to the real EFI high pressure pump. All my diesel are ran this way. Even the tractors are ran like this. These are need because they are all direct injection. Takes a huge amount of PSI to over come the compression on the engine. Diesels normally see, 1500 psi or more on the injector side of the pump. BTW the feed / boaster/ first pump have a return, it is that most are now mounted in the tank, so the return is just dumped into the tank, no extra lines etc... seen. Your correct about the direct injection high pressure pump system that's at the engine but the feed/supply pump is Pulse Width Modulated to control the pressure in the line. A pressure switch monitors the fuel line pressure and an electronic control module adjusts the supply voltage frequency to the pump accordingly so that the pump only runs if and as fast as needed. No in tank return system and no excess heat created which may be beneficial considering the front mounted radiator associated with most v8 swaps. I was wrong about the pressure required out of the supply pump. A little more research suggests that too keep the high pressure pump supplied correctly, 72 psi and 45gph is needed from the supply/feed pump. Finding a pump that fits those specs and fits in the 914 tank is the tricky part I was referring to. |
Andyrew |
Apr 5 2018, 12:35 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
From what I have read, the feed pump should be 50-60 psi which is common of cars these days. The tricky part is the engine ecu controls a PWM pump in a returnless system. (IMG:style_emoticons/default/welcome.png) Then lets get into this a bit deeper. What makes that a complicated system? Take what we like to call in the diesel world the feed pump, and mount it as close to the tank as you can get. Run one feed line back to the engine, and to the real EFI high pressure pump. All my diesel are ran this way. Even the tractors are ran like this. These are need because they are all direct injection. Takes a huge amount of PSI to over come the compression on the engine. Diesels normally see, 1500 psi or more on the injector side of the pump. BTW the feed / boaster/ first pump have a return, it is that most are now mounted in the tank, so the return is just dumped into the tank, no extra lines etc... seen. Your correct about the direct injection high pressure pump system that's at the engine but the feed/supply pump is Pulse Width Modulated to control the pressure in the line. A pressure switch monitors the fuel line pressure and an electronic control module adjusts the supply voltage frequency to the pump accordingly so that the pump only runs if and as fast as needed. No in tank return system and no excess heat created which may be beneficial considering the front mounted radiator associated with most v8 swaps. I was wrong about the pressure required out of the supply pump. A little more research suggests that too keep the high pressure pump supplied correctly, 72 psi and 45gph is needed from the supply/feed pump. Finding a pump that fits those specs and fits in the 914 tank is the tricky part I was referring to. You can always just run a surge tank and then go with a high end pump like a Bosch 044. This is what I have, I put the tank in the engine bay and have a carb pump feeding into the surge tank. My setup shouldnt run out of fuel till ~600hp on E85, and Im not likely to turn it up that much... |
Lo-Fi Version | Time is now: 19th May 2024 - 06:31 PM |
