Build Thread: Restoration and New School V8, Photogrammetry: Pics to CAD |
Joemo5 |
Apr 5 2018, 12:07 AM
Member Group: Members Posts: 54 Joined: 1-April 18 From: Charlotte, North Carolina Member No.: 22,011 Region Association: South East States |
I probably should have joined 914world and started posting earlier but I have been reading and learning ALOT about these cars already from whats posted in other threads. For that, I thank you guys. I have some catching up to do. Heres my story.
I picked up my first 914 a few months ago as a project car that could eventually serve as a track car or weekend toy. Out of the many different types of cars that would make cool projects, I ended up with the 914 in my crosshairs after I discovered that not only they were mid engine but v8 swaps where not uncommon. Other factors include I had never came across one in the wild, which makes them rare to me. I also like the idea of following in my fathers footsteps with a mid engine european car. He had a Lotus Europa in is 20's. Jumping back the v8 idea though, the added weight of a more powerful drivetrain is at the center of the car, meaning there is a minimal increase in the rotational moment of inertia: the car should retain it's handling characteristics better than a v8 swap in a comparable sized car with a forward mounted engine. After investigating several craigslist ads that turned out to have missing titles, a friend pointed me towards a local Porsche shop that was known for 914's. Bingo. More 914's than I expected. A few short conversations led to a cheap car that needed some work and was up for grabs. Heres what the '75 2.0l car looked like prior to being yanked out of the weeds. On the trailer headed home Some of my buddies and I broke out a pressure washer and the car looks good for sitting outside for a year or two. The car did not have the original engine or trans installed when purchased. Although, they were included in the sale. Some tinkering around got some of the electronics working off a jump start box Now heres the fun part. A month or two later, I came across a craigslist deal that would add some originality to the project. An 5.3l L83 out of a 2015 silverado with only "15,000" miles for $1200. Would an engine with 15,000 miles still have the assembly grease in between the rocker and top of the valve? (IMG:style_emoticons/default/confused24.gif) For those of you unfamiliar with this engine: It's NOT an LS, its part of the EcoTec Gen V family. The next generation of Chevy v8 that shares some of the architecture with the LS but with direct injection and variable valve timing. Also its an aluminum block which is different from the Gen IV 5.3 truck blocks which were cast iron. Rumor has it that GM is offering a stand alone kit for the gen V engines which, while costly, would simplify the install a lot. Quick specs: Stock 380hp and 416 ft-lbs on e85 fuel. 11.0:1 compression ratio ~400lb dressed. Anyone know how much the original 2.0l engine weighs? At this point I'm sure most of you have thought: "What does the hell hole look like?" The rot is the worst of all the ones I have viewed online. The only saving grace is that after selling the original motor, trans and wheels, I have made back the purchase price of the car and have a few bucks in my pocket. I have some experience in fabrication and plan on being a sheet metal pro by the end of all this. Heres a shot of the floor pans and fire wall area. At this point the car is stripped and ready to be mounted on a rotisserie. Lots of bracing prior to mounting on the rotisserie of course. I have more pics and more details but that should do for now. Attached image(s) |
Maltese Falcon |
Apr 7 2018, 11:50 AM
Advanced Member Group: Members Posts: 4,656 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
(IMG:style_emoticons/default/welcome.png) looks like the PO had an aftermarket a/c going on in the front trunk (IMG:style_emoticons/default/sawzall-smiley.gif) If you plan to exit your spent radiator air out the bottom, you have a head start ...just close up what you don't need !
Andyrew |
Apr 7 2018, 12:51 PM
(IMG:style_emoticons/default/welcome.png) looks like the PO had an aftermarket a/c going on in the front trunk (IMG:style_emoticons/default/sawzall-smiley.gif) If you plan to exit your spent radiator air out the bottom, you have a head start ...just close up what you don't need ! Generates to much lift under the car at speed. Wheel well or hood exhaust would be my only choices |
Lo-Fi Version | Time is now: 19th May 2024 - 05:50 PM |
