Required Voltage to Coil |
Ansbacher |
Apr 5 2018, 06:20 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
For the last month or so my '74 2.0L (carbureted) has been getting progressively harder to start, especially when sitting after running. Today it finally will not start hot or cold. I ruled out the carbs and fuel supply. I also replaced the battery when this problem arose. I am measuring 12.54 volts on the battery (static) but am only getting 11.54 volts at the +terminal of the coil with ignition on. Should that be enough to start the car? In addition, as this problem got worse, the engine running just got worse and worse, misfiring, and erratic idle. Any ideas?
Ansbacher |
iankarr |
Apr 5 2018, 06:40 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
First I’d check the grounds (behind battery, under relay panel, transsmission ground strap). The slow deterioration sounds like a loose ground that’s getting looser or more corroded over time...
Apr 6 2018, 12:09 AM
The coil needs less than 10V to work. It may even work with much lower voltage than that! You may wind up with lousy high-RPM running if the voltage drops low enough, but I think that would be quite low indeed!
My injected car ran with a non-functioning alternator until the center console voltmeter dropped below 9V. Not sure how much that was at the coil, but I figure that 9V was about when the injection gave up. I think it might have run quite a bit longer with carbs! --DD |
falcor75 |
Apr 6 2018, 12:17 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
There's no real load on the battery with just the ignition on, monitor the voltage when cranking and see if it goes much lower than the static reading.
Spoke |
Apr 6 2018, 09:29 AM
There's no real load on the battery with just the ignition on, monitor the voltage when cranking and see if it goes much lower than the static reading. (IMG:style_emoticons/default/agree.gif) Also you may read a low voltage if the coil is being energized when doing a static (engine not cranking or running) test. Coil current may be very high (much higher than when running) for a static test resulting in a larger voltage drop than seen when the engine is running or cranking. |
Ansbacher |
Apr 6 2018, 02:07 PM
OK, I got 9.5 Volts at the coil + terminal when cranking. I tried a different coil and a different condenser- still no start, just cranks. Points had just been cleaned and adjusted to a good dwell (checked when the engine was still limping). Definitely getting fuel. I cleaned the ground strap connection underneath the rear trunk, but I cannot get a wrench to the bolt that holds the other end of the ground strap to the rear of the transmission. Am I going to have to remove the muffler to get to it or is there a trick somebody knows? It does look a bit corroded and I want to clean it up. HEEELLLPP!
Ansbacher |
falcor75 |
Apr 6 2018, 02:21 PM
Could be a dead cell in the battery, if you have a pair of jumper leads try connecting them to another battery and try cranking again.
Ansbacher |
Apr 6 2018, 04:24 PM
OK, tried to jump start the car. Would not start, just cranked. Also cleaned the ground connection above the fuse panel. Cranked a bit better but would not start. Pulled a plug to watch the spark- it is definitely weak, a reddish purple, NOT bluish white like it should be.
Ansbacher |
jcd914 |
Apr 6 2018, 04:29 PM
Check your points and the ground wire on the advance plate in the distributor.
Jim |
Apr 6 2018, 05:48 PM
Do you know that you are not getting spark? Tape a spare spark plug to a ground, plug a spark plug wire into it, and have someone crank the starter while you watch the plug. Sparks will be obvious if they are happening.
--DD |
Ansbacher |
Apr 6 2018, 06:15 PM
Do you know that you are not getting spark? Tape a spare spark plug to a ground, plug a spark plug wire into it, and have someone crank the starter while you watch the plug. Sparks will be obvious if they are happening. --DD Dave, Reference two responses up (the one from me). Yes, I am getting a very weak spark. I also tried some different timing positions of the distributor, advanced and retarded. Still wont fire. Guess it is not enough to ignite the fuel. Ansbacher |
Ansbacher |
Apr 7 2018, 01:48 PM
Well, I got it running. Hard to believe, but it was plugs! Pulled out the NGKs (which looked perfectly fine) and replaced them with my used standby set of Bosch. Fired right up. What I noticed is that all of the little nipple adaptors that screw on to the threaded top of the plugs were loose as a goose on the NGKs. They would not tighten up. They went on nice and tight on the Bosch. I have to use them with the plug wires I have in order for them to snap on properly. Not sure how this happened, as things were fine when I first installed the NGKs. Anyone else run into this sort of thing?
Anyway, thanks everyone for their help on this problem. Ansbacher |
rudedude |
Apr 7 2018, 02:02 PM
Senior Member Group: Members Posts: 509 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
My honda v6 outboard motor has a slight intermittent miss and then all of a sudden wouldn't run. Turned out all 6 ngk quit at the same time. Way cheaper than the ecu I thought I was going to need
IronHillRestorations |
Apr 7 2018, 09:03 PM
How old are the points and condenser?
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 AM |
