Holy Merde!, close encounter with a leaky fuel line |
nebreitling |
Jul 11 2003, 11:39 AM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
so i went to start my 75 2.0 this morning. it has sat undriven for only 6 days, no big deal. i just removed the air pump and plugged the air injector jets last weekend.
i start it up and check out the engine bay to make sure that my plugs haven't backed out -- and i notice a very small amount of white smoke coming out of the exhaust -- i've never seen this with my car, engine runs great. perplexed, i think i smell fuel -- look back in the engine bay and notice a little pool of gasoline accumulating beneath the metal fuel rail on the drivers side (cylinders 1-2). you've never seen a guy shut off an engine so quick! thank goodness i caught it before i started driving or the engine warmed up... my question: could the white exhaust be related to this? i'm wondering if a fuel injector is plugged -- maybe that would put too much pressure in the fuel lines, making them leak? in any case i think it's time to renew all of my fuel hoses (and perhaps install a fire extinguisher) (IMG:style_emoticons/default/ohmy.gif) |
aufaber |
Jul 11 2003, 12:02 PM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
Smoke from too much fuel is blackish.. Oil smoke is blueish white.. white smoke is steam.
If you didn't drive the car for 6 days water just probably condensed in the exhaust. -Aaron G> |
airsix |
Jul 11 2003, 12:48 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Yep, scary stuff. 12 years ago when I was a poor dumb kid with my first delapidated 914 I smelled fuel one day and quickly parked and popped the engine lid. I was greeted with a nice mist of fuel. Yes, a mist. My first thought was "fuel air bomb". Yikes. The small curved piece of fuel line between an injector and the rail had developed a mall rupture. Fuel was puddling below it, and it was spraying out a mist of fuel just like an injector nozzle. Talk about worst-case. That's got to be the most combustible type of leak there is. Car didn't move an inch from that spot until I had replaced all the lines. My current 914? Drove it home from the seller's house and parked it until I had replaced all the lines. I don't like fires unless they are between a piston top and a combustion chamber. (IMG:style_emoticons/default/wink.gif)
-Ben M. |
nebreitling |
Jul 11 2003, 02:03 PM
QUOTE(airsix @ Jul 11 2003, 10:48 AM) I don't like fires unless they are between a piston top and a combustion chamber. (IMG:style_emoticons/default/wink.gif) -Ben M. my thoughts exactly!! that's a great (if disconcerting) story about the fuel mist.... you're a lucky guy.. nathan |
Brad Roberts |
Jul 11 2003, 04:51 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
So...
Pull the injectors and remove the "crimp" fitting on the fuel line to the injector and replace it with a short piece of fuel injection hose and a hose clamp. They all spring a leak at the "bend" over time. B |
Lo-Fi Version | Time is now: 15th May 2024 - 06:32 PM |
