Sandwich Adapter, Solution for fitment ? |
914work |
Apr 9 2018, 08:22 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
So I have one in the Werke shope that is a bad leak'er.
74 2.0L street car. Front mount cooler with the ubiquitous Mocal sandwich adapter which seems to be a significant (but not the entire) culprit. One of the issues that is probably contributing to the problem is the clearance of the oil filter. Due to the depth of the adapter the oil filter is low enough that the engine cross bar impacts the Oil filter. There is just enough clearance, but given the eng. bar is rubber mounted its without a doubt vibrating on the filter body. Anyone else deal with this & what was the solution. I checked the rubber mounts & they are in good shape. Different filter brand? Space out the Motor mounts off the case? Thanks Attached thumbnail(s) |
dlee6204 |
Apr 10 2018, 06:21 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I think it's the 944 filter that is shorter and will fit just fine (IMG:style_emoticons/default/agree.gif) I think so too |
Lo-Fi Version | Time is now: 17th May 2024 - 03:59 PM |
