914 fuel injected distributor |
amcmackin |
Apr 10 2018, 10:40 AM
Newbie Group: Members Posts: 7 Joined: 2-December 13 From: Minden, NV Member No.: 16,714 Region Association: Northern California |
I have been absent for a while and my car has sat, but upon running the car around i notice that the power was gone in the upper RPMs. I put electronic ignition in it thinking that might help, but it did not. After taking it to a shop they told me the distributor was bad.
The shop wants me to replace the distributor which is the original vacuum advance one, with a 123 distributor. I am looking to sell the car, so putting a $500+ distributor is not on my agenda. Is there any way to loose the vacuum advance or am I stuck having this original one rebuilt. Not looking to break the bank either. Aidan |
914Sixer |
Apr 12 2018, 06:31 PM
914 Guru Group: Members Posts: 8,878 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Tom,
You should be able to change the FI points with out taking out distributor. |
TJB/914 |
Apr 12 2018, 06:56 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Tom, You should be able to change the FI points with out taking out distributor. Thanks Mark I took the winter cover off my 914 then with a fresh battery cranked it to start. The engine makes a mini start up, then nothing. I suspect the trigger points are the issue. Never happened before after winter storage. Tom |
Lo-Fi Version | Time is now: 12th May 2024 - 01:58 AM |
