914 Radiator Mounting |
Francesco |
Apr 10 2018, 03:35 PM
Newbie Group: Members Posts: 10 Joined: 21-February 17 From: Ventura County, CA Member No.: 20,864 Region Association: Southern California |
Hey all,
Planning on a water pumper engine swap for my 914, and I see most of the radiator mounts involve cutting the hood or venting air outwards someway involving that. I already have the floor cut for factory A/C (not there any more and don't plan on keeping A/C with the engine swap), and I was curious if I could mount a radiator horizontal, and direct air out of the bottom of the car. I know this will cause lift, but I'm unsure how much it will cause at speed, and if it will actually be an issue? I'd like to maintain as much as my trunk as I possibly can, that's why mounting it 100% horizontally is appealing to me. Thank you for your critisim, Francesco |
tazz9924 |
Apr 10 2018, 06:31 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
You definitely could, you’d need some good fans as it’s gonna get worse air flow. If possible mount them so the pull air through instead of push so their more efficient. As for lift i cant attest to the amount of lift it may cause, you may consider and air dam for the front and/or a diffuser on the back to prevent/ evacuate some of the air under the car (only worry about this if you’re planning high speed not just freeway to 100mph)
Lo-Fi Version | Time is now: 26th April 2024 - 09:52 AM |
