914 Radiator Mounting |
Francesco |
Apr 10 2018, 03:35 PM
Newbie Group: Members Posts: 10 Joined: 21-February 17 From: Ventura County, CA Member No.: 20,864 Region Association: Southern California |
Hey all,
Planning on a water pumper engine swap for my 914, and I see most of the radiator mounts involve cutting the hood or venting air outwards someway involving that. I already have the floor cut for factory A/C (not there any more and don't plan on keeping A/C with the engine swap), and I was curious if I could mount a radiator horizontal, and direct air out of the bottom of the car. I know this will cause lift, but I'm unsure how much it will cause at speed, and if it will actually be an issue? I'd like to maintain as much as my trunk as I possibly can, that's why mounting it 100% horizontally is appealing to me. Thank you for your critisim, Francesco |
smonigold |
Apr 10 2018, 08:59 PM
Newbie Group: Members Posts: 2 Joined: 7-June 12 From: long beach,cali. Member No.: 14,536 Region Association: Southern California |
Hey all, Planning on a water pumper engine swap for my 914, and I see most of the radiator mounts involve cutting the hood or venting air outwards someway involving that. I already have the floor cut for factory A/C (not there any more and don't plan on keeping A/C with the engine swap), and I was curious if I could mount a radiator horizontal, and direct air out of the bottom of the car. I know this will cause lift, but I'm unsure how much it will cause at speed, and if it will actually be an issue? I'd like to maintain as much as my trunk as I possibly can, that's why mounting it 100% horizontally is appealing to me. Thank you for your critisim, Francesco I used a radiator and fans out of 924. Inlet is the 916 oil cooler hole" fiberglass front bumper" made ducting with aluminum and exited out hole in hood. Runs too cool going down highway never overheat even in Los Angeles traffic. But mine has a SR20DET in it. Not too keen on idea of cutting tub. And it only weighs 1800 lbs so power to weight ratio is excellent. |
Lo-Fi Version | Time is now: 28th March 2024 - 07:37 AM |
