914 Radiator Mounting |
Francesco |
Apr 10 2018, 03:35 PM
Newbie Group: Members Posts: 10 Joined: 21-February 17 From: Ventura County, CA Member No.: 20,864 Region Association: Southern California |
Hey all,
Planning on a water pumper engine swap for my 914, and I see most of the radiator mounts involve cutting the hood or venting air outwards someway involving that. I already have the floor cut for factory A/C (not there any more and don't plan on keeping A/C with the engine swap), and I was curious if I could mount a radiator horizontal, and direct air out of the bottom of the car. I know this will cause lift, but I'm unsure how much it will cause at speed, and if it will actually be an issue? I'd like to maintain as much as my trunk as I possibly can, that's why mounting it 100% horizontally is appealing to me. Thank you for your critisim, Francesco |
Francesco |
Apr 11 2018, 06:26 PM
The motor will be a Subaru 4 cylinder motor, so I'm sure not nearly as big of a radiator will be required as a V8 would.
A&P Mech |
Apr 11 2018, 09:01 PM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
The first subaru motor I installed in my 914 was a 2.5L four cylinder EJ253. To be honest it was okay. It was more power than the stock type 4 but the acceleration was still a bit uninspiring. I would routinely get spanked on the freeway on ramps by aggressive soccer moms in mini vans.
I had the opportunity to drive a 914 with a 3.0 subaru 6 cylinder installed and after that I couldn't replace the 2.5L installed in my car fast enough. I truly believe the ez30 subaru 6 cylinder is a perfect match for the 914. The balance feel of the car along with a respectable amount of torque makes it a total kick in the pants to drive. (IMG:style_emoticons/default/driving.gif) |
Francesco |
Apr 12 2018, 08:10 AM
The first subaru motor I installed in my 914 was a 2.5L four cylinder EJ253. To be honest it was okay. It was more power than the stock type 4 but the acceleration was still a bit uninspiring. I would routinely get spanked on the freeway on ramps by aggressive soccer moms in mini vans. I had the opportunity to drive a 914 with a 3.0 subaru 6 cylinder installed and after that I couldn't replace the 2.5L installed in my car fast enough. I truly believe the ez30 subaru 6 cylinder is a perfect match for the 914. The balance feel of the car along with a respectable amount of torque makes it a total kick in the pants to drive. (IMG:style_emoticons/default/driving.gif) Planning on a turbo EJ20 from Japan, with ~275 hp stock, should push 300 NO problem with a tune, I think I will get in more than enough trouble with that, lol. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:46 PM |
