914 Radiator Mounting |
Francesco |
Apr 10 2018, 03:35 PM
Newbie Group: Members Posts: 10 Joined: 21-February 17 From: Ventura County, CA Member No.: 20,864 Region Association: Southern California |
Hey all,
Planning on a water pumper engine swap for my 914, and I see most of the radiator mounts involve cutting the hood or venting air outwards someway involving that. I already have the floor cut for factory A/C (not there any more and don't plan on keeping A/C with the engine swap), and I was curious if I could mount a radiator horizontal, and direct air out of the bottom of the car. I know this will cause lift, but I'm unsure how much it will cause at speed, and if it will actually be an issue? I'd like to maintain as much as my trunk as I possibly can, that's why mounting it 100% horizontally is appealing to me. Thank you for your critisim, Francesco |
76-914 |
Apr 13 2018, 08:55 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,490 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sounds like you've done your homework. Are you using petrolicious to re-flash the ECU? I didn't need to re-flash anything for my 6 cylinder install. I have one USM and one JDM engine; both 3.0's. The only difference I found on this model was one of the 4 Molex engine connectors was different. Since I already had the US version harness it was only a matter of switching out the one small harness. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 25th April 2024 - 11:05 PM |
