GT Flare and matching Rocker Panel, Side view Completed |
Nacho |
Apr 11 2018, 07:04 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Hi Everyone
Does anyone have a good side view picture of a GT flared 914 with matching rocker panels? I can only find angled side view pictures. I'm trying to understand the contour of the fender flare to rockers flare alignment and wheel well arch line. I purchased mb911 rocker flare end pieces and I'm trying to install them. Thanks |
mepstein |
Apr 11 2018, 07:15 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Here’s a pic on a private built GT. Just remember that the fiberglass rockers of the GT’s didn’t match the contours well and even had variations in length from left to right. You have the chance to make your rockers fit better than the factory ever did.
Attached thumbnail(s) |
Nacho |
Apr 11 2018, 07:27 PM
Here’s a pic on a private built GT. Just remember that the fiberglass rockers of the GT’s didn’t match the contours well and even had variations in length from left to right. You have the chance to make your rockers fit better than the factory ever did. Thanks. Hopefully we can get some examples of more accurately installed rockers. I'm converting stock rockers with mb911's flare ends. |
mepstein |
Apr 11 2018, 08:50 PM
Here’s a pic on a private built GT. Just remember that the fiberglass rockers of the GT’s didn’t match the contours well and even had variations in length from left to right. You have the chance to make your rockers fit better than the factory ever did. Thanks. Hopefully we can get some examples of more accurately installed rockers. I'm converting stock rockers with mb911's flare ends. I have a set of them as well. Hopefully I can get Ben to weld them up for me some day. I would imagine you clamp the ends to your rockers, move them around until they look right and then cut the rocker and weld on the ends. |
burton73 |
Apr 11 2018, 09:48 PM
burton73 Group: Members Posts: 3,493 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Here’s a pic on a private built GT. Just remember that the fiberglass rockers of the GT’s didn’t match the contours well and even had variations in length from left to right. You have the chance to make your rockers fit better than the factory ever did. Thanks. Hopefully we can get some examples of more accurately installed rockers. I'm converting stock rockers with mb911's flare ends. I have a set of them as well. Hopefully I can get Ben to weld them up for me some day. I would imagine you clamp the ends to your rockers, move them around until they look right and then cut the rocker and weld on the ends. (IMG:style_emoticons/default/agree.gif) The install of flares can be off an inch or so and each car is different. Test fit. Then cut and weld. Bob B |
Lo-Fi Version | Time is now: 24th April 2024 - 10:17 PM |
