Injector Upgrade, new parts for fuel injection |
McMark |
Apr 12 2018, 11:42 AM
I've been working on upgrading the components of my custom fuel injection setup. One of the upgrades I've had in the works for awhile was adapting the newest Bosch injectors. These have an improved spray pattern, are high-impedance, and are available in a variety of spray volumes. And they're TINY!
But like any of this stuff, you can't just bolt them on. I decided to make some fancy adapters that would look mostly original. This was one of my first projects to help teach myself Fusion360 CAD modeling. Got a couple 3D prints from some of our members, which illustrated a few issues with my design. A few changes were made and I pulled the trigger on an initial run of 20 pieces (5 engines). Just received these parts back from anodizing and did a final test fit. Everything looks perfect. So it's time to install this and my upgraded AAR on my 1.7 Turbo and see how these new additions help things. |
Dave_Darling |
Apr 16 2018, 12:23 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
McMark |
Apr 16 2018, 02:19 PM
I think I need to order some 90-degree elbows... Or perhaps extend the fitting a bit and have it make a ~75 degree bend?--DD This was what I settled on as the best solution to that issue. |
Dave_Darling |
Apr 16 2018, 07:20 PM
The problem there is that the 1.7 an 2.0 runners have the fittings at different angles. So any angle I build in will make two versions necessary. (IMG:style_emoticons/default/pinch.gif) Ah, poop. No good compromise angle that will work OK with either, then? That's a bummer. --DD |
Lo-Fi Version | Time is now: 19th April 2024 - 12:30 PM |
