Injector Upgrade, new parts for fuel injection |
McMark |
Apr 12 2018, 11:42 AM
I've been working on upgrading the components of my custom fuel injection setup. One of the upgrades I've had in the works for awhile was adapting the newest Bosch injectors. These have an improved spray pattern, are high-impedance, and are available in a variety of spray volumes. And they're TINY!
But like any of this stuff, you can't just bolt them on. I decided to make some fancy adapters that would look mostly original. This was one of my first projects to help teach myself Fusion360 CAD modeling. Got a couple 3D prints from some of our members, which illustrated a few issues with my design. A few changes were made and I pulled the trigger on an initial run of 20 pieces (5 engines). Just received these parts back from anodizing and did a final test fit. Everything looks perfect. So it's time to install this and my upgraded AAR on my 1.7 Turbo and see how these new additions help things. |
McMark |
Apr 23 2018, 12:04 PM
Why not build a fuel rail with proper openings for the injectors to fit into and seal as designed? I looked at it, but machining costs were just as high and I don't like the way it looks. These brackets hold the injectors FIRMLY. I will still be doing pressure testing for possible leaks, but my initial impression of them mounted is that a fuel rail wouldn't add anything for rigidity.Have you changed the lower orings on the injectors? Yup. I cut off the round oring and the plastic support, then the stock square o-ring fits perfectly. Lucky accident.They look different to the standard round oring that is normally fitted to these style injectors. I assume you are fitting original style square rings? Cheers |
Lo-Fi Version | Time is now: 19th April 2024 - 06:37 AM |
