CHT temps, individual cylinder differences? |
falcor75 |
Apr 12 2018, 10:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
For those of you that are running 4 CHT sensors under the plugs, what differences do you see between the cylinders?
Whats your typical temps for each cylinder with: A: Engine warmed up sitting at idle for a minute or two. B: Engine warmed up, cruising at 50-55 mph in fifth gear. |
jcd914 |
Apr 20 2018, 05:29 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Too bad.
Their description says there is a vacuum balance tube between the cylinders, if there is and it is open there should not be any flow difference at idle. But then I am not sure what they are describing r what its function is. Jim |
Lo-Fi Version | Time is now: 6th May 2024 - 03:02 PM |
