CHT temps, individual cylinder differences? |
falcor75 |
Apr 12 2018, 10:50 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
For those of you that are running 4 CHT sensors under the plugs, what differences do you see between the cylinders?
Whats your typical temps for each cylinder with: A: Engine warmed up sitting at idle for a minute or two. B: Engine warmed up, cruising at 50-55 mph in fifth gear. |
falcor75 |
Apr 15 2018, 05:28 AM
Just spend the last 3 hours fiddling with the thottles.
Started with disconnecting the throttle cable and making sure the 1-2 (master) side was as closed as it would possibly go. Then I hooked up the throttle cable again and made sure there was no slack in the slave cable to the 3-4 side so both sides open simultaneously. I started the engine and let it warm up for about 10 minutes at different rpms. (the neighbours love me) Then I took out the air gauge and started measuring. To start with 1 drew the most air, followed by 3 and 4 and last 2. By first adjusting the slave cable slightly and then the idle air screws I got cylinder 1,3 and 4 to draw the same amount of air, just below the 6 mark on the scale. CHT temps at idle was then around 110C (320F) for #1 and 125C (257F) for # 3 and #4. Cylinder 1 Cylinder 2 The odd one out is still #2, when the others draw just below the 6 mark, #2 draws like 4,5-4,8, about a full scale marker lower and the temp is around 95 C or 205F. What could cause #2 to draw that much less air? air leak between head and manifold, airleak between manifold and throttle body are the only things I can come up with.... |
Lo-Fi Version | Time is now: 25th April 2024 - 08:25 PM |
